Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will demonstrate how to replace the touch pad in the Asus X501A-RH31 laptop. Please note, the touch pad is a sensitive piece of the laptop, execute caution when taking out the touch pad.
Выберете то, что вам нужно
To unlock the right tab, push the right slider to the left with one hand.
Push the battery out with the other hand.
Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
Pry off the keyboard cover on the edge using the plastic opening tool.
Start from one side. Once it is lose, carry out the same procedure on the front and other side.
Slowly lift the keyboard upward, but do not remove completely.
Remove the two data cables that attach the keyboard to the motherboard.
Use tweezers to pull the white plastic piece up that is attached to the data cable.
Repeat this process for the big black cable as well.
Flip the keyboard over so the side without the keys is facing you.
Using the Phillips #00 screwdriver, unscrew the three screws.
Detach the white data cable on the back of the touch pad.
Use tweezers to pull the white plastic piece up that is holding in the cable.
Peel the tan tape that holds the touch pad to the back of the keyboard.
Slide the touch pad up and out of the metal plate located near the bottom on the touch pad and keyboard.
Еще один человек закончил это руководство.
