Asus X502C-RB01 Network Card Replacement
Выберете то, что вам нужно
  1. Asus X502C-RB01 Network Card Replacement, Keyboard Panel: шаг 1, изображение 1 из 1
    • Turn off the laptop and flip it face down.
    • Using a Phillips #0 screwdriver, remove the seven 9mm screws circled in red.
    • With the same screwdriver, remove the four 5mm screws circled in orange.
  2. Asus X502C-RB01 Network Card Replacement: шаг 2, изображение 1 из 1
    • Flip the laptop face up and open the lid.
    • Use the plastic opening tool to pry around the entire edge of the keyboard panel to loosen the panel from the base.
    • Be careful not to lift the panel just yet, as it is still connected to the motherboard.
  3. Asus X502C-RB01 Network Card Replacement: шаг 3, изображение 1 из 2 Asus X502C-RB01 Network Card Replacement: шаг 3, изображение 2 из 2
    • Partially lift the panel up, revealing the two cables connected to the motherboard.
  4. Asus X502C-RB01 Network Card Replacement: шаг 4, изображение 1 из 2 Asus X502C-RB01 Network Card Replacement: шаг 4, изображение 2 из 2
    • Disconnect the first ZIF cable by lifting the tab using the spuger tool or your fingernail and gently pull the cable out.
    • Disconnect the second ZIF cable by lifting the tab using your fingernail and gently pull the cable out. This one is more difficult to reach with the spudger.
  5. Asus X502C-RB01 Network Card Replacement: шаг 5, изображение 1 из 1
    • Remove the keyboard panel completely and set it aside. The internal components of the laptop are now exposed.
  6. Asus X502C-RB01 Network Card Replacement, Hard Drive: шаг 6, изображение 1 из 1
    • Locate the hard drive in the area highlighted in red.
    • This demonstration model does not have a mounting bracket around the hard drive.
  7. Asus X502C-RB01 Network Card Replacement: шаг 7, изображение 1 из 1
    • Remove the four 5mm screws from the hard drive mounting bracket using the Phillips #0 screwdriver.
  8. Asus X502C-RB01 Network Card Replacement: шаг 8, изображение 1 из 1
    • Slide the hard drive in the direction away from the connector and lift it up to remove it.
  9. Asus X502C-RB01 Network Card Replacement, Motherboard: шаг 9, изображение 1 из 1
    • Unplug the battery from the laptop by lifting the connector up with the flat end of the spudger.
    • Unplug the two ZIF cables by lifting the tab using the spudger tool or your fingernail then pulling the cable out gently.
  10. Asus X502C-RB01 Network Card Replacement: шаг 10, изображение 1 из 1
    • Unplug the bundled cable by pulling it away from the connector with a bit of force.
    • Unplug the display cable connector by lifting the tape and pulling it away from the connector.
    • Unplug the two antenna cables connected to the network interface card by prying it off with the flat end of the spudger.
  11. Asus X502C-RB01 Network Card Replacement: шаг 11, изображение 1 из 2 Asus X502C-RB01 Network Card Replacement: шаг 11, изображение 2 из 2
    • Remove the four 5.5mm screws using the Phillips #0 screwdriver.
  12. Asus X502C-RB01 Network Card Replacement: шаг 12, изображение 1 из 1
    • Gently lift the motherboard out of the casing.
  13. Asus X502C-RB01 Network Card Replacement, Network Card: шаг 13, изображение 1 из 1
    • Flip over the motherboard so that the network card is now visible.
  14. Asus X502C-RB01 Network Card Replacement: шаг 14, изображение 1 из 1
    • Remove the 5mm screw in the corner of the network card with a Phillips #0 screwdriver.
  15. Asus X502C-RB01 Network Card Replacement: шаг 15, изображение 1 из 1
    • Lift the network card up and pull it out.
    • The network card may lift itself up to the angle pictured on its own.
Заключение
2 участников успешно повторили данное руководство.
Richard Hambrick
Участник с: 01/19/17
164 Репутация
1 руководство автора
Команда
UC Davis, Team 1-5, Rodger Winter 2017 Участник UC Davis, Team 1-5, Rodger Winter 2017
UCD-RODGER-W17S1G5
4 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 538
