Введение
The performance and longevity of the battery will decline with age. This guide will show you how to replace it.
Выберете то, что вам нужно
Remove the 11 screws from the bottom of the laptop with the Phillips #00 screwdriver.
Use the Plastic Opening Tool to pry the keyboard assembly away from the rest of the laptop.
While lifting the keyboard assembly, use the tweezers to gently remove the keyboard cable and the touch pad cable by pulling the wires away from the laptop base. Both cables must be gently but firmly pulled towards you for safe removal.
Using the Phillips #00 screwdriver, unscrew the 6 screws holding the battery in place.
