Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Asus X540S notebook PC Hard drive Replacement
Выберете то, что вам нужно
    • Open the Optical Drive to allow removal of keyboard before powering down computer.
  1. Asus X540S notebook PC Hard drive  Replacement: шаг 2, изображение 1 из 1
    • Remove the two 15mm Philips #1 screws.
    • Remove the two 12mm Philips #1 screws.
    • Remove the six 9mm Philips #1 screws.
  2. Asus X540S notebook PC Hard drive  Replacement: шаг 3, изображение 1 из 3 Asus X540S notebook PC Hard drive  Replacement: шаг 3, изображение 2 из 3 Asus X540S notebook PC Hard drive  Replacement: шаг 3, изображение 3 из 3
    • Lift the side of the top.
    • Remove the keyboard cable.
    • Remove the trackpad cable.
    • Lift the release tabs on the keyboard/trackpad connectors
    When removing both cables there is a small black plastic flap covering the connection.
    GENTLY lift that flap and GENTLY lift the end of the cable/ribbon and you're good to go.
    My first try I was under the impression it was more of a plug and didn't see any specifics just like above “remove cable” but no description of how.
    Even though I did it wrong, it didn't damage anything, and this guide was a big help.
    F S - Ответить
    Added a note. Thanks for the comment!
    Padraic Hoselton -
    While lifting the lid, it's useful to have a spudger to detach the snaps from the top
    Emily Klassen - Ответить
  3. Asus X540S notebook PC Hard drive  Replacement, Hard drive: шаг 4, изображение 1 из 2 Asus X540S notebook PC Hard drive  Replacement, Hard drive: шаг 4, изображение 2 из 2
    • Remove the one Philips #1 screw.
    • Slide the hard drive out.
  4. Asus X540S notebook PC Hard drive  Replacement: шаг 5, изображение 1 из 2 Asus X540S notebook PC Hard drive  Replacement: шаг 5, изображение 2 из 2
    • Remove the four Philips #1 screws.
    Wanted to add:
    Must open dvd drawer first to pull up on top housing
    Can only spudge after pulling up on top above DVD opening - stiff expired credit card works good
    No hidden screws, the ones on the bottom are it
    Only 2 ribbon cables, keyboard and touchpad
    Ribbon cables are short, keeping plastic clamps secured on them tricky when reassembling
    Very helpful guide, thank you :)
    Avery Freeman - Ответить
Заключение
18 участников успешно повторили данное руководство.
Padraic Hoselton
Участник с: 08/22/17
4 180 Репутация
Автор 12 руководств
Команда
Master Techs Участник Master Techs
Community
321 членов
Автор 1 490 руководств
7 Комментариев
Looks simple enough Padraic. Thanks. Does a new install of win10 come already copied in a new HDD? Would this replacement be and different if I used a digital drive? (My old hd failed and I have no system).
sludge - Ответить
After installing an OEM replacement HDD in my x540, I bought a flash drive on Amazon for$10 that rebooted my Windows 10 and it's working like a brand new machine.
I believe the product key for windows 10 is embedded in motherboard.
F S -
F S - Ответить
Hi … How can a flashdrive reboot a Win10 on a new SDD /HDD ? A Windows flash drive contains a Win10 bootable ISO ?
On Amazon, I found flash drives with a product key but I don’t know where the new installation can be done from if there is no ISO on it …
(I have a x540 with a dead HDD …)
gnogno35 -
And thank you Padraic
F S - Ответить
No problem!
I will add a note to the keyboard and trackpad on step 2
Padraic Hoselton -
@paperboypaddy what hard drive did you use and what brand? Mine just bit the dust.
Erica O - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 46
За всё время: 13,905
