Введение
This guide focuses on the steps required to change out the RAM for the Asus Model X550ZA-SA100603E. It will go step by step in the order required for disassembly. Once finished with the RAM change, doing the steps in reverse order will put the device back together.
Place the computer screen side down and remove the 14 mm and 4 mm screws on the bottom of the computer. Locate all 10 screws and completely unscrew them. Make sure to keep the screws for reassembly.
Carefully turn the computer onto its bottom, and gently pull the bottom apart from the top.
Take a flathead driver, and gently pry open a gap between the keyboard and the lower piece. This should uncover the laptop's internals.
The motherboard is the big board on the left-hand side of the internals. Remove all bordering screws that hold the motherboard in place.
Carefully flip the motherboard over to expose the bottom of the board. You should find the RAM slots located on the right-hand side of the bottom of the motherboard.
Take two fingers and pull the securing slots outward. The RAM stick should easily pop out. Take the old stick out, and carefully put the new one in the slot. Push until you hear a clicking noise.
Еще один человек закончил это руководство.
