Asus X5511M-RCLN03 Optical Drive Replacement
Выберете то, что вам нужно
  1. Asus X5511M-RCLN03 Optical Drive Replacement, Optical Drive: шаг 1, изображение 1 из 1
    • Position the laptop with the back cover facing upward.
  2. Asus X5511M-RCLN03 Optical Drive Replacement: шаг 2, изображение 1 из 1
    • Remove all nine 4 mm screws from the back cover.
  3. Asus X5511M-RCLN03 Optical Drive Replacement: шаг 3, изображение 1 из 1
    • Open the laptop with the keyboard facing upward."
  4. Asus X5511M-RCLN03 Optical Drive Replacement: шаг 4, изображение 1 из 1
    • Pry up the keyboard using a plastic spudger.
  5. Asus X5511M-RCLN03 Optical Drive Replacement: шаг 5, изображение 1 из 1
    • Remove the four, 4 mm screws using a Phillips #00 screwdriver.
  6. Asus X5511M-RCLN03 Optical Drive Replacement: шаг 6, изображение 1 из 1
    • Slide out the CD-ROM.
Заключение
Еще один человек закончил это руководство.
Andrew Hemphill
Участник с: 01/12/17
179 Репутация
1 руководство автора
Команду
Oakland University, Team 2-5, Ruskiewicz Winter 2017 Участник Oakland University, Team 2-5, Ruskiewicz Winter 2017
OAK-RUSKIEWICZ-W17S2G5
3 членов
Автор 2 руководств
3 Комментариев
Peer Review:
Title: This should be changed, as this portion of the device is not a DVD player. It is a CD ROM drive.
Step 1: This step is unclear and seems unnecessary. It should be removed, or reworded to be more specific: "Position the laptop with the back cover facing upward."
-Step 2: This step should specify what screwdriver to use. Using markup in the image would also help the user with locating the screws.
Step 3: This step is also unclear and seems unnecessary. It should be removed, or reworded: "Re-position the laptop with the back cover facing downward."
Courtney Clark - Ответить
-Step 4: This step is missing articles (i.e. pry up “the” keyboard using a spudger). Also, it should specific what spudger to use (plastic). The user should know not to use a metal spudger on their device.
Step 5: This step is missing an article (remove “the” screw).
Step 6: This step is unclear, and should refer to the “CD ROM drive”, not a DVD player. It should be reworded to be more clear. Example: “Slide out the CD ROM drive to remove it.”
Edit the title and link to the guide so that they say CD-ROM drive instead of DVD player.
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 11
За всё время: 758
