Введение
LCD displays are vulnerable to damage and can crack easily. This is one of the most frequently damaged parts on a laptop, so it is good to know how to replace it!
Выберете то, что вам нужно
Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
Two 4.3 mm screws in the back corners
One 17.5 mm screw at the left edge near the optical drive
Three 4.3 mm screws in the front edge
Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
Invert the laptop in order to gain access to the ribbons.
Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
Yes and you have to put lotion on
Now, that is a stupid question! Of course! As I am working on 551M, I naturally have to have nails painted orange, with blue accents!
that boy ain't right
Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
Once the screws have been removed, place your fingers on the left corners and push the hard drive towards the right edge of the laptop (relative to the picture).
Using the Phillips #0 Screwdriver, unscrew the 5.5 mm Phillips #0 screw that holds the spacer in place.
Remove the spacer from the laptop by gently sliding it towards the right edge of the laptop.
Use the Phillips #0 Screwdriver to unscrew the 3.2 mm Phillips #0 screw which attaches the WiFi card to the motherboard.
Disconnect the Wifi card from the motherboard by gently sliding it towards the right edge of the laptop.
Remove each of the two small antenna connections by disconnecting one wire at a time. Each wire should easily unsnap from the Wifi card.
This computer uses a Mini PCIe slot card, as you can see in the photo's. You can órder almost any card, from either FENVI brand (Intel) or Artheros (Qualcomm), just make certain you order a card that specifically says it is a HALF HEIGHT Mini PCI-e card. Intel stop producing cards like this after the 7265HMW card but other brands make compatible cards. In the Intel design, any card that ends in 'HMW' is a card that is a mini PCIe card. If you see any other combination of letters then it is not likely to be compatible.
If you have any questions, ask the vendor if the card is compatible with your computer.
Remove the battery from the laptop by applying pressure on both ends and lifting it out of the case.
With the Phillips #0 Screwdriver, remove the nine 5.5 mm Phillips #0 screws which hold the motherboard in place.
Remove the wires by easily pulling them parallel to the motherboard's surface.
You should never pull plugs out by the wires themselves. ALWAYS use a tool to release the plug itself by inserting a spudger between the plug and socket, and gently easing it out. Pulling by the wires risks damaging the wires, or ripping the socket off the motherboard.
Remove the LCD display connection by gently pulling on the attached wire.
Gently lift any tape that may be holding the connection.
If the tape is removed when disconnecting, be SUPER sure that the connector is the right way before reconnecting. I managed to brake this connector by putting it in the wrong way! Both sides look very similar.
Locate both of the hinges that connect the monitor to the bottom plate cover.
Use the Phillips #0 screwdriver to unscrew the two 4.8 mm Phillips #0 screws on the right hinge, and the one 4.8 mm Phillips #0 screw on the left hinge.
Once the screws are removed, the monitor should easily lift away from the bottom plate cover
Locate the two stickers that cover up the screws that hold the front bezel in place
Why not just remove the bezel and swap the LCD out with the screen assembly still attached to the bottom half?
Once the stickers are removed, the two screws that hold the front bezel in place will be exposed.
Once the screws are taken out, the front bezel is ready to be removed.
Insert the Plastic Opening Tool inbetween the front and back bezels and slide along the edges to pry open.
Once pried away from the back bezel, the front bezel will easily lift away from the LCD.
Use the Philips #0 screwdriver to remove the twelve 3.2 mm Phillips #0 screws that hold the LCD in place.
Once the screws are removed, lift up the LCD to expose the wire connecting the back bezel to the LCD.
Gently unhook the wire from the back bezel to allow the LCD to be flipped over.
10 участников успешно повторили данное руководство.
Один комментарий
You don't need to disassemble the entire unit to get the panel out. Seems an overkill
screw assignments are definitely wrong. I swapped the red and the green, as per comment above, and kept the blue as-is.
jasonbuechler - Ответить
jason is right
starwilson - Ответить
correct, swap the green and red
Josh - Ответить
Jason is correct
Clem Lanoe - Ответить
Thanks everyone. It does seem like someone got their screws mixed up when they wrote this guide. I’ve made some changes as you all suggested, so the screw placements should be more accurate now. If anyone with this laptop could verify the screw measurements with a digital caliper, that’d also be very helpful.
Jeff Suovanen - Ответить
