Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
The Asus X551CA power button allows the laptop to turn on and off. If it is broken, the laptop will not receive the signal to boot up.
Запчасти
Детали не указаны.
  1. Power off and unplug your laptop before you begin.
    • Power off and unplug your laptop before you begin.
    • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
  2. Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
    • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
  3. Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
    • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
  4. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Invert the laptop in order to gain access to the ribbons. Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon. Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
    • Invert the laptop in order to gain access to the ribbons.
    • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
  6. Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
    • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
  7. Locate the power button in the corner  of the keyboard plate cover.
    • Locate the power button in the corner of the keyboard plate cover.
    • Disconnect the ribbon from the small green board by flipping up the small white flap and pulling parallel to the green board's surface.
  8. Remove the two 3.2 mm Phillips #0 screws on the power button using the Phillips #0 Screwdriver.
    • Remove the two 3.2 mm Phillips #0 screws on the power button using the Phillips #0 Screwdriver.
  9. Remove the power button assembly by firmly grasping it from both sides and lifting it off of the keyboard plate cover.
    • Remove the power button assembly by firmly grasping it from both sides and lifting it off of the keyboard plate cover.
Заключение
7 участников успешно повторили данное руководство.
Josh
Участник с: 10.04.2014
2 722 Репутация
Автор 12 руководств
Команда
Cal Poly, Team 7-22, Regan Spring 2014 Участник Cal Poly, Team 7-22, Regan Spring 2014
CPSU-REGAN-S14S7G22
5 членов
Автор 15 руководств
Один комментарий
I broke the middle ribbon! Do you know if that is replaceable? What part number would I order?
crwfd - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 9
За последние 30 дней: 51
За всё время: 10,105
