Asus X551CA Spacer Replacement
Выберете то, что вам нужно
  1. Asus X551CA Spacer Replacement, Keyboard Plate Cover: шаг 1, изображение 1 из 1
    • Power off and unplug your laptop before you begin.
    • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
  2. Asus X551CA Spacer Replacement: шаг 2, изображение 1 из 1
    • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
  3. Asus X551CA Spacer Replacement: шаг 3, изображение 1 из 1
    • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
  4. Asus X551CA Spacer Replacement: шаг 4, изображение 1 из 3 Asus X551CA Spacer Replacement: шаг 4, изображение 2 из 3 Asus X551CA Spacer Replacement: шаг 4, изображение 3 из 3
    • Invert the laptop in order to gain access to the ribbons.
    • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
  5. Asus X551CA Spacer Replacement: шаг 5, изображение 1 из 1
    • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
  6. Asus X551CA Spacer Replacement, Spacer: шаг 6, изображение 1 из 1
    • Using the Phillips #0 Screwdriver, unscrew the 5.5 mm Phillips #0 screw that holds the spacer in place.
  7. Asus X551CA Spacer Replacement: шаг 7, изображение 1 из 1
    • Remove the spacer from the laptop by gently sliding it towards the right edge of the laptop.
Заключение
4 участников успешно повторили данное руководство.
Josh
Участник с: 04/10/14
2 958 Репутация
Автор 12 руководств
Команда
Cal Poly, Team 7-22, Regan Spring 2014 Участник Cal Poly, Team 7-22, Regan Spring 2014
CPSU-REGAN-S14S7G22
5 членов
Автор 15 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 1,670
