Asus X555LA-SI305041 CD Drive Replacement
Выберете то, что вам нужно
  1. Asus X555LA-SI305041 CD Drive Replacement, Keyboard Assembly: шаг 1, изображение 1 из 1
    • Remove the following Phillips #0 screws from the lower case:
    • Six 9 mm screws
    • Four 11 mm screws
  2. Asus X555LA-SI305041 CD Drive Replacement: шаг 2, изображение 1 из 1
    • Use the plastic opening tool to separate the top cover from the laptop.
    • Start by prying on the front of the laptop.
    • Continue prying around the cover and end just under the screen to release the front cover.
    • Do not fully remove the top cover, it is attached by two ribbon cables that will be disconnected in the following steps.
  3. Asus X555LA-SI305041 CD Drive Replacement: шаг 3, изображение 1 из 1
    • To release the ZIF latch, flip up the small white tab.
    • The connector may have a white base with a small grey rotating latch.
    • Pull the white ribbon cable out of the socket to disconnect it.
    • Very little force should be required to pull out the cable.
  4. Asus X555LA-SI305041 CD Drive Replacement: шаг 4, изображение 1 из 1
    • To release the ZIF latch on the keyboard cable, flip the grey rotating tab up.
    • Gently pull the black and blue ribbon cable out of its connector.
  5. Asus X555LA-SI305041 CD Drive Replacement: шаг 5, изображение 1 из 1
    • You can now fully remove the keyboard and front panel to gain access to the inside of the laptop.
  6. Asus X555LA-SI305041 CD Drive Replacement, CD Drive: шаг 6, изображение 1 из 1
    • Using a #0 Phillips screw driver, remove the (5mm) black screw to the left of the CD Drive and to the right of the cooling fan.
  7. Asus X555LA-SI305041 CD Drive Replacement: шаг 7, изображение 1 из 1
    • CD Drive should easily slide out.
Заключение
9 участников успешно повторили данное руководство.
Alex Turner
Участник с: 09/28/15
1 864 Репутация
Автор 3 руководств
Команда
Eastern Washington University, Team 1-1, Matresse Fall 2015 Участник Eastern Washington University, Team 1-1, Matresse Fall 2015
EWU-MATRESSE-F15S1G1
4 членов
Автор 13 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 21
За всё время: 7,826
