Введение
This guide will demonstrate the process for replacing the RAM in this laptop. This could be useful if your RAM is not working properly or if you would like to upgrade your RAM. This will be one of the easiest replacements in this device. RAM is designed to be replaced and upgraded, so it was made very easy to access. RAM is basically the computer's temporary memory, NOT the computer's storage. One thing to note, this bay may be empty as one stick of RAM is soldered into the motherboard and is not serviceable by the end-user. If it is this stick that is defective, you will need to file an RMA. However if it is the stick in the bay that is defective, then please proceed with this repair guide.
Выберете то, что вам нужно
Flip your laptop upside down and set it on a solid surface.
The RAM is located under the square cover on the bottom of the laptop.
Using a #0 Phillips screwdriver, unscrew the single 2.5mm screw on the RAM cover.
With your finger, push the two metal tabs (one on each side) outward until the RAM card pops up.
18 участников успешно повторили данное руководство.
6 Комментариев
Hi! The battery have not be removed before this?
Ariel, the battery should be removed but this creates very unnecessary strain and stress on you. This is just an expansion bay, the actual ram is soldered on the motherboard, not serviceable by the end-user. Again, this is an expansion bay so what that means is if no RAM is in the to begin with, the laptop will be fine because there is still RAM directly on the motherboard. This is just so the end-user can add more RAM if they so choose.
What if it comes with 2GB RAM already in the bay? Is it okay to proceed as long as the PC is shutdown? Will I lose any information by removing the 2GB RAM stick? Thanks. (My X555LAB has 6GB RAM total but I wish to replace the 2GB with an 8GB, 12GB total, even though this PC has the i7 CPU which I heard can handle more than 12GB of RAM, something like 32GB but apparently this PC can handle only 12GB even though it has an i7 8th gen processor) Any advice?
Guys, so there is 4 GB RAM on the MOBO, and I can even add another 8 on top, having 12? Or I can add not more than 4 since it says that max for this laptop is 8. Please advise.
