Введение
We will show you how to open the laptop and change / upgrade the HDD (hard disk drive).
Please SUBSCRIBE to my channel ツ
Video Overview
  1. Switch off the Laptop and remove the Battery. Unscrew the two Philips screws and remove the HDD / RAM Cover. Unscrew the two Philips screws and remove the HDD / RAM Cover.
    • Switch off the Laptop and remove the Battery.
    • Unscrew the two Philips screws and remove the HDD / RAM Cover.
  2. Комплект инструментов для замены батареи Macbook
    Доступно с $69.99
    Buy Now
    Доступно с $69.99
    Buy Now
  3. Remove three screws securing the hard drive caddy (hard drive assembly). Slide the hard drive assembly to the left to disconnect it from the motherboard. Slide the hard drive assembly to the left to disconnect it from the motherboard.
    • Remove three screws securing the hard drive caddy (hard drive assembly).
    • Slide the hard drive assembly to the left to disconnect it from the motherboard.
  4. Remove the two Philips screws and separate the HDD from the caddy case.
    • Remove the two Philips screws and separate the HDD from the caddy case.
    • You can install 2.5" SATA HDD, 5400rpm / 7200rpm, 320GB / 500GB / 750GB /1TB.
    • After changing / upgrading the HDD you must install an operating system or clone & copy the information from the old HDD to the new one.
    • Did you do it successfully.
    • Please SUBSCRIBE to my channel ツ
Заключение
3 участников успешно повторили данное руководство.
ZFix
Участник с: 09.12.2013
164 019 Репутация
Автор 305 руководств
Команда
Master Techs Member of Master Techs
Community
286 членов
Автор 808 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 3
За 7 дней: 21
За 30 дней: 78
За всё время: 6,883
