Введение
This guide will will walk you through the process of removing and replacing a faulty DVD Drive.
Выберете то, что вам нужно
With the screen closed, place your laptop upside-down with the front facing you.
Remove the six 14.6mm Phillips #00 screws.
Remove the four 6.6mm Phillips #00 screws.
Flip the laptop over and open the lid.
Pry around the edges of the laptop base using the plastic opening tool.
Carefully lift the keyboard up.
Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
With the keyboard panel open, face the laptop with the internal components facing towards you.
Remove the single 4.6mm Phillips #00 screw.
2 участников успешно повторили данное руководство.
