Введение
The Asus X751MA-DH01TQ has a built in webcam that is easy to access with this guide.
Выберете то, что вам нужно
Turn the laptop upside down and locate the ten screws that hold the plate cover.
Remove all ten screws using a 00 Phillips head screwdriver.
Using the plastic opening tool, pry the keyboard off of the base of the laptop.
Lift up and remove the keyboard.
Remove the stickers from the bottom left and right corners of the screen.
Use a 00 Phillips head screw driver to remove the four screws.
Once the sticker is peeled off pull the plug holding the webcam into the circuit board and the webcam is now disconnected.
