Выберете то, что вам нужно
Turn the laptop upside down.
Unscrew the 10 screws on the bottom of the laptop using a PH00 screwdriver bit.
Remove the eight 5.5 Phillips #00 screws located at the top right and left hand side of panel.
Remove the four 4mm Phillips #00 screws on the bottom left and right of the screen.
Insert the plastic opening tool on the side of the screen and slide it all the way around to open the screen up.
Remove the eight total screws (4 on each side) that are on the side of the white part on the back of the screen.
Remove the two 4mm Phillips #00 screws on the top corners of the back of the screen.
Remove the metal bars that you have just unscrewed.
Peel back the bronze sticker that is connecting the white border piece to the outside edge of the screen.
