Asus Zen AiO Pro Z240IC RAM Replacement
Выберете то, что вам нужно
  1. Asus Zen AiO Pro Z240IC RAM Replacement, Screen: шаг 1, изображение 1 из 2 Asus Zen AiO Pro Z240IC RAM Replacement, Screen: шаг 1, изображение 2 из 2
    • Use the plastic opening tool to pry off the black plastic strip at the bottom of the screen by wiggling the tool between the strip and the screen.
    • The strip is held in place with adhesive. You may hear a crackling sound as the strip is peeled off.
    • Run the opening tool slowly along the base of the screen, peeling the black strip back, until the opposite end of the screen is reached.
    On my machine, it was positively impossible to use a plastic opening tool, or even a razor to get under the plastic strip - even after heating up with a heat gun. However, I found another method that will also help prevent damage to the plastic strip: in pictures for Steps 2 and 3, you can see that under the plastic strip, next to some of the screws there are square holes in the plastic body. I was able to shape a sturdy paper clip into an “L” shape, and feed it through the right-most exhaust vent at the bottom to insert into this square hole from below. From there, you can use the paper clip to try to push the plastic strip up from below. It still required some heat from the heat gun, but eventually I was able to push the plastic strip up enough to be able to slip a razor blade under it.
    Alexander V Trofimuk - Ответить
    I too was unable to do this with the plastic tools, but used a small flat screwdriver to ply up the corned on the bottom curved corner and plastic tools form there - just left a small blemish on the plastic besel, but I can live with that.
    Andy Monaghan - Ответить
  2. Asus Zen AiO Pro Z240IC RAM Replacement: шаг 2, изображение 1 из 2 Asus Zen AiO Pro Z240IC RAM Replacement: шаг 2, изображение 2 из 2
    • Use a Phillips #1 screwdriver to remove the seven (7) 4.8 mm screws from the base of the screen.
  3. Asus Zen AiO Pro Z240IC RAM Replacement: шаг 3, изображение 1 из 3 Asus Zen AiO Pro Z240IC RAM Replacement: шаг 3, изображение 2 из 3 Asus Zen AiO Pro Z240IC RAM Replacement: шаг 3, изображение 3 из 3
    • Place the computer on its back, facing up.
    • Wedge the plastic opening tool in between the screen and the bezel of the aluminum computer casing.
    • Move the tool along the entire edge of the screen with an up-and-down prying motion to loosen the screen from the casing. Do not lift the entire screen away from the computer yet.
    • The screen is held in place by plastic tabs. These will create a popping sound when loosened.
    • The screen assembly will flex as it is pried off. Do not bend the screen too far or the glass screen could shatter.
    It’s a lot easier to use two suction cups on the bottom corners, and then slide some cards in between the screen and the case.
    Alec - Ответить
  4. Asus Zen AiO Pro Z240IC RAM Replacement: шаг 4, изображение 1 из 1
    • Lift the screen from the bottom edge by about 6 inches. Prop it open with one hand.
    • Look inside the computer and locate five (5) cables that connect the embedded components of the screen (camera, microphone, etc.) to the rest of the computer.
    I have this model, but I only found 4 cables, 2 were ribbon cables. Just look inside and unplug anything that is connecting the display to the motherboard.
    Alec - Ответить
    Same here my model just had 4 cables.
  5. Asus Zen AiO Pro Z240IC RAM Replacement: шаг 5, изображение 1 из 3 Asus Zen AiO Pro Z240IC RAM Replacement: шаг 5, изображение 2 из 3 Asus Zen AiO Pro Z240IC RAM Replacement: шаг 5, изображение 3 из 3
    • Remove the two (2) cables that are connected to the computer by white, rectangular terminal blocks by pulling straight out on the plug.
    • The cables and wires in these steps are delicate; do not tug on the individual wires that make up each cable.
  6. Asus Zen AiO Pro Z240IC RAM Replacement: шаг 6, изображение 1 из 3 Asus Zen AiO Pro Z240IC RAM Replacement: шаг 6, изображение 2 из 3 Asus Zen AiO Pro Z240IC RAM Replacement: шаг 6, изображение 3 из 3
    • Use a finger to lift the plastic locking flaps that hold the remaining three (3) ribbon cables in place.
    • Remove the cables from their terminals by slipping them away from their connectors.
    • The black line on the ribbon cables mark the connecting region. When reinstalling, insert the cable up to this line so the locking flap covers it.
    When re-connecting take great care to ensure the ribbon cables are square and flat - I had to take mine apart again to re-seat one as the screen was blank - worked fine once re-seated properly.
  7. Asus Zen AiO Pro Z240IC RAM Replacement, Fan: шаг 7, изображение 1 из 2 Asus Zen AiO Pro Z240IC RAM Replacement, Fan: шаг 7, изображение 2 из 2
    • Use a Phillips #0 screwdriver to remove the three (3) 4.8 mm screws from the fan unit.
    • Remove the cable connecting the fan to the motherboard by pulling the cable out of its socket.
  8. Asus Zen AiO Pro Z240IC RAM Replacement: шаг 8, изображение 1 из 1
    • Remove the fan by peeling off the black electrical tape holding it against the heat sink vents.
  9. Asus Zen AiO Pro Z240IC RAM Replacement, WiFi (WLAN) Card: шаг 9, изображение 1 из 3 Asus Zen AiO Pro Z240IC RAM Replacement, WiFi (WLAN) Card: шаг 9, изображение 2 из 3 Asus Zen AiO Pro Z240IC RAM Replacement, WiFi (WLAN) Card: шаг 9, изображение 3 из 3
    • Locate the WLAN card in the upper left hand corner of the computer.
    • Use a Phillips #1 screwdriver to remove the 3.2 mm screw on the top of the WLAN card.
  10. Asus Zen AiO Pro Z240IC RAM Replacement: шаг 10, изображение 1 из 3 Asus Zen AiO Pro Z240IC RAM Replacement: шаг 10, изображение 2 из 3 Asus Zen AiO Pro Z240IC RAM Replacement: шаг 10, изображение 3 из 3
    • Pull out the WLAN card from its socket.
    • Remove the two antennae wires from the WLAN card by pulling up on the coaxial connectors.
  11. Asus Zen AiO Pro Z240IC RAM Replacement, Motherboard: шаг 11, изображение 1 из 1
    • Remove the six (6) ribbon cables by lifting up on the plastic locking tabs and then slipping the cables out of their sockets.
    • Remove the other two (2) cables by pulling straight out on the white connectors.
    • One ribbon cable is hidden beneath black tape.
    • The motherboard is ESD sensitive. Limit your contact with the green circuit board surface and electrical components. When handling the board, hold it by the edges.
    • The black lines on the ribbon cables mark the connecting region. When reinstalling, insert the cables up to this line so the locking flap covers it.
  12. Asus Zen AiO Pro Z240IC RAM Replacement: шаг 12, изображение 1 из 2 Asus Zen AiO Pro Z240IC RAM Replacement: шаг 12, изображение 2 из 2
    • Use a Phillips #1 screwdriver to remove nine (9) 3.2 mm screws from the motherboard.
    • Two of the screws near the middle of the board are hidden beneath padding.
    • Use a Phillips #1 screwdriver to remove the one (1) 4.8 mm screw directly below the copper heat sink channel.
  13. Asus Zen AiO Pro Z240IC RAM Replacement: шаг 13, изображение 1 из 2 Asus Zen AiO Pro Z240IC RAM Replacement: шаг 13, изображение 2 из 2
    • Lift the motherboard just enough to dismount it from the plastic pegs that hold it in place.
    • Rotate the motherboard towards yourself while supporting the heat sink by pivoting on its bottom edge.
  14. Asus Zen AiO Pro Z240IC RAM Replacement: шаг 14, изображение 1 из 2 Asus Zen AiO Pro Z240IC RAM Replacement: шаг 14, изображение 2 из 2
    • Remove the SATA cable on the opposite side of the motherboard by pulling directly up from the board.
  15. Asus Zen AiO Pro Z240IC RAM Replacement, RAM: шаг 15, изображение 1 из 2 Asus Zen AiO Pro Z240IC RAM Replacement, RAM: шаг 15, изображение 2 из 2
    • Remove the metal shield covering the ram by pulling straight up on the shield itself.
    • The shield is held in place by small metal clips at each corner. These clips are fragile, but have a strong grip, so some force may be required to pry the shield loose.
  16. Asus Zen AiO Pro Z240IC RAM Replacement: шаг 16, изображение 1 из 3 Asus Zen AiO Pro Z240IC RAM Replacement: шаг 16, изображение 2 из 3 Asus Zen AiO Pro Z240IC RAM Replacement: шаг 16, изображение 3 из 3
    • Push down on the two metal tabs on each side of the RAM stick. This will cause the stick to spring up slightly.
    • Remove the RAM from its socket.
    • Repeat the last two bullets on the other RAM stick.
    • RAM sticks are not symmetrical. When reinstalling the RAM, make sure the notch on the RAM's contact surface lines up with the bar inside the slot.
    what kind of ram can i insert here?
    Louise Neilson Fuentes - Ответить
Заключение
8 участников успешно повторили данное руководство.
Jessica Lerena
Участник с: 10/02/17
630 Репутация
Автор 4 руководств
Команда
Cal Poly, Team S4-G1, Livingston Fall 2017 Участник Cal Poly, Team S4-G1, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G1
5 членов
Автор 25 руководств
4 Комментариев
This was a great guide. The only thing I would add is to push “out” on the ram clips instead of down to actually get it out. I spent an unreasonable amount of time trying to push down and realized after a while it just wasn’t going to loosen anything up that way! Just upgraded my ram so thanks.
Stesha Doku - Ответить
Great job! Beside RAM, wich type of disk drive will be more performance on this ASUS model? Can a ssd M2 be set for the system and use the mechanic HD for storage? Thanks
joseefsimoes - Ответить
Late reply, but theoretically you could, but you do need an appropriate screw or double sided tape to keep it in place and reinstall Windows onto the new drive to get everything set up correctly (that means back up your data!).
Also do pay attention to the type of SSD you are shopping for, as it looks like the connector looks like it is set up for proper blazing fast M.2 NVMe 2280 (22mm wide, 80mm long) SSD. There are some SSDs on the market that have two notches on them which may or may not work with this computer but will still fit.
Adrian Kennedy -
je vient de terminer l"opérations avec succès . j'aie maintenant 32 gh ram et 1 to ssd de disque dur une vraie bombe
Pierre Garceau - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 27
За последние 30 дней: 118
За всё время: 10,917
