Введение
This guide will walk through the necessary steps to replace the keyboard on your Asus Zenbook Flip UX360C.
Выберете то, что вам нужно
Turn laptop over.
Use the metal spudger to pry rubber feet off in the four corners of laptop.
Flip device upside down, and remove the eleven 5 mm #1 Phillips case screws.
Flip the device back over.
Insert an opening tool between the keyboard assembly and bottom casing, and slide it around the edge to pop the keyboard assembly free.
