Введение
The wi-fi wireless card allows your device to connect to the internet via a wireless connection, and is a vital part of your device.
Выберете то, что вам нужно
Remove all ten T5 screws on the back cover near the edges.
Remove two Phillips #1 screws located under the rubber feet near the screen.
Use a metal spudger to gently separate the keyboard from the computer case.
Lift the keyboard slightly, and use a plastic spudger to release the two ZIF connections to free each ribbon cable.
Remove the keyboard.
Use a plastic opening tool or nylon spudger to lift the monitor connections off of the main board.
Remove the black foam above the screw on the I/O board.
Remove the 5 mm #1 Phillips head screw.
Pull the I/O board away from the chip to detach it.
Remove the I/O board and main board.
Use the metal spudger to remove the chip connections.
Gently pull the chip up and to the left to remove it from the device.
