Введение
This guide will show you how to replace the motherboard on an Asus ZenBook UX303U laptop.
Выберете то, что вам нужно
Pull the speaker cable out of its four retaining clips with either your fingers, or a plastic opening tool.
Pull the speaker connector toward the edge of the laptop to disconnect it from its socket.
Lift the battery connector straight up off its socket to disconnect it from the motherboard.
Disconnect the display cable from the motherboard with a plastic opening tool.
Remove the three 6mm Phillips #00 screws from the hinge.
Remove the 2mm Phillips #00 screw from the plastic housing securing the fan into place.
Disconnect all wires connecting the motherboard to the rest of the device.
For the two connectors marked in orange, lift the black clip up to release the wire.
For the wire marked in yellow, lift it straight up.
4 участников успешно повторили данное руководство.
Один комментарий
The bottom of the pictured device may feature Phillips #00 screws, but I also have this laptop and the screws around the edge of the bottom panel are Torx T5s on my device.
