Asus ZenFone 2 Battery Replacement
Выберете то, что вам нужно
  1. Asus ZenFone 2 Battery Replacement, Removing the Back Cover: шаг 1, изображение 1 из 2 Asus ZenFone 2 Battery Replacement, Removing the Back Cover: шаг 1, изображение 2 из 2
    • Use your fingernail to gently pry off the phone's back cover at the indicated location. While your fingernail is under the back cover slide your finger around the edges of the phone until the cover pops off.
  2. Asus ZenFone 2 Battery Replacement, Remove the Inner Cover Screws: шаг 2, изображение 1 из 1
    • Remove the thirteen black screws and the single silver screw from the back of the phone with a JIS size 00 screwdriver.
    • The black screws are 2.8 mm in length.
    • The silver screw is 5.5 mm in length.
    • The black screw next to the camera and the flash is covered by a sticker. This screw can be easily removed as if there were no sticker on top of it. The point of the screwdriver should be able to pierce through the sticker easily.
  3. Asus ZenFone 2 Battery Replacement, Remove the Inner Cover: шаг 3, изображение 1 из 2 Asus ZenFone 2 Battery Replacement, Remove the Inner Cover: шаг 3, изображение 2 из 2
    • Use a plastic opening tool to remove the inner phone backing.
    • The parts of the inner backing held down by two strips of double sided tape can be easily loosened by inserting the plastic opening tool underneath it and gently lifting it up.
  4. Asus ZenFone 2 Battery Replacement, Remove the Speaker: шаг 4, изображение 1 из 1
    • Note the position of the speaker unit so you can replace it in the correct place during reassembly.
    • Take the speaker out of the back of the phone. It should come out easily as soon as the inner back is removed because nothing is holding it down in place anymore.
  5. Asus ZenFone 2 Battery Replacement, Battery: шаг 5, изображение 1 из 1
    • Use a plastic prying tool to carefully detach the bottom part of the antenna.
    • The antenna can be easily bent out of shape. Be sure to lift from underneath the cable as shown.
  6. Asus ZenFone 2 Battery Replacement: шаг 6, изображение 1 из 2 Asus ZenFone 2 Battery Replacement: шаг 6, изображение 2 из 2
    • Using the plastic opening tool, unlock the ribbon cable indicated in the picture by prying up the yellow tab.
  7. Asus ZenFone 2 Battery Replacement: шаг 7, изображение 1 из 1
    • Using a plastic opening tool, remove the vibration motor from its housing.
  8. Asus ZenFone 2 Battery Replacement: шаг 8, изображение 1 из 1
    • Gently remove the board from the phone using your hand.
  9. Asus ZenFone 2 Battery Replacement: шаг 9, изображение 1 из 2 Asus ZenFone 2 Battery Replacement: шаг 9, изображение 2 из 2
    • Using the plastic opening tool, gently pry the ribbon cables up as indicated in the pictures.
  10. Asus ZenFone 2 Battery Replacement: шаг 10, изображение 1 из 1
    • Carefully remove the battery pack from the phone using your hand.
    • There are fragile tabs on the left and right side of the battery, be careful not to break them off.
  11. Asus ZenFone 2 Battery Replacement: шаг 11, изображение 1 из 3 Asus ZenFone 2 Battery Replacement: шаг 11, изображение 2 из 3 Asus ZenFone 2 Battery Replacement: шаг 11, изображение 3 из 3
    • Carefully insert the metal spudger between the battery and its metal housing and then slowly pry the two apart.
    • Be careful when prying the two apart as to not bend the outer edges of the metal housing because this will make it a lot more difficult to put it back into the phone.
Заключение
Put in a new battery and then reassemble your device by following these instructions in reverse order.
83 участников успешно повторили данное руководство.
Eduardo Nodarse
Участник с: 02/10/16
4 797 Репутация
Автор 5 руководств
Команда
USF Tampa, Team 2-5, Sullivan Spring 2016 Участник USF Tampa, Team 2-5, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G5
4 членов
Автор 16 руководств
31 Комментариев
Great job with excellent photographs and detailed explanations! Unfortunately this phone is a real goat rodeo when it comes to just replacing a battery. My phone froze and nothing seemed to help unlock it. Fortunately, I went back to an Android site and found the answer and was able to reboot it (holding the on/off button for 10-15 seconds) without trying to remove the battery. Thanks to you I've learned two valuable lessons.
Michael Pobjecky - Ответить
How can i buy the battery for my Zenfone 2 ze550ml .I want 100% original li-po battery.
Skanda - Ответить
my zenfone 2 charging very long time and berry laevel vry sort time discharge
shailendra - Ответить
i replaced my Zenfone 2 ze551ml's battery carefully.
But when i put everything back ,it can not turn on .
the vibration motor is the only thing working
every few minutes the vibration will vibrate two times itself.
Can anyone tell me how to solve this problem,thanks
angus - Ответить
Hi there I'm having the same problem with my phone, did you get any responses on how to fix the problem
mcummings197023 -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 19
За последние 30 дней: 94
За всё время: 86,080
