Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Prerequisite Only
Выберете то, что вам нужно
Use your fingernail to gently pry off the phone's back cover at the indicated location. While your fingernail is under the back cover slide your finger around the edges of the phone until the cover pops off.
Remove the thirteen black screws and the single silver screw from the back of the phone with a JIS size 00 screwdriver.
The black screws are 2.8 mm in length.
The silver screw is 5.5 mm in length.
Use a plastic opening tool to remove the inner phone backing.
Take the speaker out of the back of the phone. It should come out easily as soon as the inner back is removed because nothing is holding it down in place anymore.
40 участников успешно повторили данное руководство.
