Выберете то, что вам нужно
Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
Carefully slide your iFixit Opening Tool between the back panel.
Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
Disconnect the battery from the motherboard by gently pulling up and down on the connector.
Using the Phillips #00 screwdriver, remove the screws from the middle and the two corners of the battery.
Remove the battery. (Picture-1)
Picture of what the battery looks like.(Picture-2)
5 участников успешно повторили данное руководство.
2 Комментариев
Thanks for the easy to understand guide. Cheers!
Thanks for the guideline it easy to understand and easy to follow. Thanks again!
