Выберете то, что вам нужно
Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
Carefully slide your iFixit Opening Tool between the back panel.
Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
Disconnect the battery from the motherboard by gently pulling up and down on the connector.
Using the Phillips #00 screwdriver, remove the screws from the middle and the two corners of the battery.
Remove the battery. (Picture-1)
Picture of what the battery looks like.(Picture-2)
Use the plastic opening tool to pry open the back cover of the laptop.
Remove the bottom panel of the laptop.
Remove the screw connecting the speaker component to the motherboard using the screwdriver.
Using the plastic opening tool, pry open the speaker component from the computer.
Peel back the warranty sticker to reveal the screw under it.
Using your Phillips #00 Precision Screwdriver, unscrew the screw that you just revealed.
Disconnect the fan connector from the motherboard.
Pull up the clips on the ribbon connectors.
Using a plastic opening tool, lift the fan off of the laptop.
You can now use your hands and carefully pull the fan off the laptop.
At the marked locations, unscrew 7 screws with your Phillips 00 Precision Screwdriver.
At the marked locations (under certain components), unscrew 3 screws with your Phillips 00 Precision Screwdriver.
Carefully pull out the ribbon connecting your keyboard and motherboard from the motherboard.
At the bottom right corner of your laptop, carefully pull the connector from its socket.
Carefully pull the black wire with a copper connector out from its socket.
Carefully pull the white wire with a copper connector out from its socket.
At the corners between your screen and the rest of your laptop, unscrew 4 screws with your Phillips 00 Precision Screwdrivers.
Slide the display to either the left or right to loosen it.
Pull the display away from the rest of your laptop.
5 участников успешно повторили данное руководство.
