Введение
If the HD web camera is not functioning this guide will teach you how to get behind the screen cover to replace the camera.
Note: Be sure the camera is broken and not just a software issue before you replace it.
Выберете то, что вам нужно
Heat the adhesive behind the screen frame with a hair dryer or a heat gun.
Unplug the bundled cable connector.
Pull the cable away from the connector in the same direction as the individual wires are running.
2 Комментариев
what type/model/code for its replacement camera ? so i cant find it in part store...
Thank you for the demo. It appears to be easy to replace the camera per your instructions. Kind regards. Mehran Gerami
