Введение
Use this guide to replace noisy or malfunctioning GPU fan in the Asus Zenbook UX32VD.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:T5 Torx Screwdriver$9.99
Remove the twelve 3 mm bottom panel screws with a T5 Torx Screwdriver.
Use a plastic opening tool to pry along the perimeter of the bottom panel until it can be easily removed.
Remove the bottom panel from the body of the laptop.
Set aside the bottom panel.
Инструмент, используемый на этом этапе:Phillips #0 Screwdriver$5.49
Remove the 3 (4mm) fan screws with a Phillips #0 Screwdriver
Unplug the bundled cable connector.
Pull the cable away from the connector in the same direction as the individual wires are running.
