Введение
The number pad, while not used in many games, can become unresponsive over time due to dislodged/dirty sensors. Reseating and cleaning them can improve number pad responsiveness.
Выберете то, что вам нужно
Turn the controller over, exposing the three screws on the back (marked by the orange circles). Use a 6mm screwdriver to remove these screws.
Carefully slide and pull the two parts of the controller shell apart, exposing the innards.
Take out the rubber button module of the number pad.
With access to the number pad sensors, use compressed air to blow out dust.
Wipe the sensors clean with a cloth dabbed with alcohol.
Use a spudger to remove the top frame.
Take off the plate.
Remove the rubber buttons.
Pull the circuit strip through the new space.
Realign the top and bottom of the controller.
Return the buttons to the top of the controller.
Snap the frame back into place.
Screw the screws.
Еще один человек закончил это руководство.
