Введение
The number pad, while not used in many games, can become unresponsive over time due to dislodged/dirty sensors. Reseating and cleaning them can improve number pad responsiveness.
Запчасти
Детали не указаны.
  1. Turn the controller over, exposing the three screws on the back (marked by the orange circles). Use a 6mm screwdriver to remove these screws. Carefully slide and pull the two parts of the controller shell apart, exposing the innards. Try not to move the joystick when reassembling. This will almost assuredly break your alignment. The less the joystick is moved, the easier it will be to realign the joystick to the pots.
    • Turn the controller over, exposing the three screws on the back (marked by the orange circles). Use a 6mm screwdriver to remove these screws.
    • Carefully slide and pull the two parts of the controller shell apart, exposing the innards.
    • Try not to move the joystick when reassembling. This will almost assuredly break your alignment. The less the joystick is moved, the easier it will be to realign the joystick to the pots.
  2. Take out the rubber button module of the number pad. With access to the number pad sensors, use compressed air to blow out dust. Wipe the sensors clean with a cloth dabbed with alcohol.
    • Take out the rubber button module of the number pad.
    • With access to the number pad sensors, use compressed air to blow out dust.
    • Wipe the sensors clean with a cloth dabbed with alcohol.
  3. Use a spudger to remove the top frame. Take off the plate.
    • Use a spudger to remove the top frame.
    • Take off the plate.
    • Remove the rubber buttons.
  4. Pull the circuit strip through the new space. Realign the top and bottom of the controller.
    • Pull the circuit strip through the new space.
    • Realign the top and bottom of the controller.
  5. Return the buttons to the top of the controller. Snap the frame back into place. Screw the screws.
    • Return the buttons to the top of the controller.
    • Snap the frame back into place.
    • Screw the screws.
Заключение
Еще один человек закончил это руководство.
Alan Abelson
Участник с: 26.09.2014
233 Репутация
Автор 5 руководств
Команда
USF Tampa, Team 13-1, Staggers Fall 2014 Участник USF Tampa, Team 13-1, Staggers Fall 2014
USFT-STAGGERS-F14S13G1
5 членов
Автор 16 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 364
