Введение
This repair guide will help you with the following:
- Install the left headphone cable
- Fix sound coming from the left headphone
Запчасти
No parts specified.
Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
Desolder the red, yellow, and blue wires using a soldering iron and desoldering wick. If you need assistance, reference How To Solder and Desolder Connections.
Untie the knot in the thick main cable.
Remove the main cable from the headphones by pulling it out.
Thread the replacement cable into the hole on the bottom of the headphones. Pull the cable all the way through.
Re-solder the new red, yellow, and blue wires using a soldering iron. If you need assistance, reference How To Solder and Desolder Connections.
