Audio Technica ATH-AD500 Left Headphone Cable Replacement
Выберете то, что вам нужно
  1. Audio Technica ATH-AD500 Left Headphone Cable Replacement, Speaker Assembly: шаг 1, изображение 1 из 1
    • Remove the ear pads by peeling them away from the grill.
    My jbl waerless headphone speaker changes how price
    Max Mad - Ответить
    How to install the earpads
    rangaranju - Ответить
  2. Audio Technica ATH-AD500 Left Headphone Cable Replacement: шаг 2, изображение 1 из 1
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Audio Technica ATH-AD500 Left Headphone Cable Replacement: шаг 3, изображение 1 из 1
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  4. Audio Technica ATH-AD500 Left Headphone Cable Replacement, Left Headphone Cable: шаг 4, изображение 1 из 3 Audio Technica ATH-AD500 Left Headphone Cable Replacement, Left Headphone Cable: шаг 4, изображение 2 из 3 Audio Technica ATH-AD500 Left Headphone Cable Replacement, Left Headphone Cable: шаг 4, изображение 3 из 3
    • Desolder the red, yellow, and blue wires using a soldering iron and desoldering wick. If you need assistance, reference How To Solder and Desolder Connections.
    • The areas where you desolder will be hot so wait until the desoldered joints are cool before handling the wires again.
  5. Audio Technica ATH-AD500 Left Headphone Cable Replacement: шаг 5, изображение 1 из 2 Audio Technica ATH-AD500 Left Headphone Cable Replacement: шаг 5, изображение 2 из 2
    • Untie the knot in the thick main cable.
    • Remove the main cable from the headphones by pulling it out.
    • Thread the replacement cable into the hole on the bottom of the headphones. Pull the cable all the way through.
    “Thread the replacement cable into the hole on the bottom of the headphones“ what replacement cables?
    John S - Ответить
    Hey, read my comment on the bottom of the guide if it’s still relevant to you.
    Erez Dahan -
    I have the same question, what replacement cable do I need?
    Erez Dahan - Ответить
  6. Audio Technica ATH-AD500 Left Headphone Cable Replacement: шаг 6, изображение 1 из 3 Audio Technica ATH-AD500 Left Headphone Cable Replacement: шаг 6, изображение 2 из 3 Audio Technica ATH-AD500 Left Headphone Cable Replacement: шаг 6, изображение 3 из 3
    • Re-solder the new red, yellow, and blue wires using a soldering iron. If you need assistance, reference How To Solder and Desolder Connections.
    • The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again.
Заключение
3 участников успешно повторили данное руководство.
Melanie Reis
Участник с: 01/11/13
227 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 17-19, Forte Winter 2013 Участник Cal Poly, Team 17-19, Forte Winter 2013
CPSU-FORTE-W13S17G19
6 членов
Автор 17 руководств
2 Комментариев
Thank you so much! your guide helped me repair my AD900x!
Anwar X - Ответить
Not sure if it’s on purpose or not but on my A900Xs the cable is on the left headphone and so, the one on the right is the one with the tiny wire going through, I found that a 2 core wire is needed for this replacement, I only managed to find one that’s 1,4mm diameter and it seems to be a little thicker than what’s actually inside the headphones but I figured I’ll give it a try, anyways here’s the wire I found on AliExpress https://www.aliexpress.com/item/40004436...
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 20
За последние 30 дней: 42
За всё время: 9,629
