Введение
This guide will deal with how to replace the broken or missing belt drive for Audio-Technica AT-LP60BK-BT Bluetooth Wireless Turntable. The rubber band could cause a malfunction and break after using a long time or under extreme temperatures.
Before using this guide, make sure the size of the new belt is designed specifically for this model to avoid motor overheat problem.
Выберете то, что вам нужно
Find the belt underneath the platter by rotating the platter to the correct place.
Remove the belt from the motor pulley.
Turn the platter around.
Grab the belt around with a finger through one of the holes in the platter.
Еще один человек закончил это руководство.
