Введение
At times, the gear that rotates in the Audio-Technica LP60XBT turntable can become old and worn causing it to break. The replacement of the gear is relatively fast and simple and can save the user a lot of money by not buying a new turntable. A successful replacement of the gear can eliminate waste in landfills; when discarded in landfills, record players can leak chemicals that are toxic to humans.
Выберете то, что вам нужно
Turn the platter so that the brass motor pulley can be seen through one of the two outer holes in the platter.
If the drive belt is hooked around the motor pulley, unhook it.
Remove the platter by grasping the platter by its two inner holes and lifting it upwards.
Remove the large white gear by pulling it upwards.
Remove the small white gear and base by pulling them upwards.
Insert the small replacement gear first, then the large replacement gear second.
