Введение
The Audiovox CDM-8900 is a flip phone with a camera and blue lights on either side of the hinge. In the case where you would have to replace the camera, you would have to remove the camera from the logic board of the cell phone prior. You may do this with the following guided steps.
Выберете то, что вам нужно
Hold the phone in one hand, slide the latch up, and pull the battery up to remove it.
Remove the small rubber insert from the top of the phone to access the top screw.
Unscrew all five screws on the back of the cell phone with a Phillips #00 screwdriver.
Wedge the phone plate toward you, using the leverage from an opening tool.
Detach the motherboard from the LCD screen connector by gently detaching the small copper plate on the top right of the motherboard.
To release the motherboard, push the large "OK" button located on the other side of the phone.
