Введение
Here is how you replace the logic board from the cell phone.
Hold the phone in one hand, slide latch, and pull to remove the battery.
  • Hold the phone in one hand, slide latch, and pull to remove the battery.
Добавить комментарий
Grasp antenna at its base and unscrew.
  • Grasp antenna at its base and unscrew.
  • Remove the antenna along with its plastic casing from inside the battery housing. Keep the antenna in the plastic casing for reassembly.
  • Remove small rubber insert from top of phone to access the top screw.
  • Warning: Screws are very small and may be difficult to see while unscrewing.
  • Unscrew all five (5) screws on the back of cell phone.
  • If screws do not remove after fully unthreading, gently invert and tap phone in hand until the screws come loose.
  • Wedge back plate away from cell phone using the leverage from the plastic spudger.
  • The volume control button on the left side of the phone will be loose. Make sure to carefully reinsert during reassembly.
  • Detach logic board from LCD screen connector by gently detaching the small copper plate on the top right of the logic board. (shown circled in blue and detached)
  • Pop the logic board out from the front of the cell phone.
  • Before reassembly, be sure keypad is lined up with logic board.
  • Before reassembly, be sure camera lens is properly aligned at the top of the logic board and volume controls are in place.
  • Grasp camera.
  • Slide camera out of slot from logic board.
  • Camera is difficult to reassemble; there is a white clip for easy camera replacement. Verify that you orient the camera correctly when reinserting.
  • Attach camera to new logic board.
  • Follow steps in reverse order to replace logic board.
Заключение
Aaron Shaw
Участник с: 15.04.2010
150 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 28-31, Regan Spring 2010 Member of Cal Poly, Team 28-31, Regan Spring 2010
CPSU-REGAN-S10S28G31
4 членов
Автор 14 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 2,573
