Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
The LCD screen is the main display of the Audiovox CDM-8910.
Запчасти
Детали не указаны.
  1. With phone in the flipped-open position, use a spudger to remove the four (4) rubber pads (one shown in red circle) located near the corners of the face with the LCD screen.
    • With phone in the flipped-open position, use a spudger to remove the four (4) rubber pads (one shown in red circle) located near the corners of the face with the LCD screen.
  2. Use a small Phillips head screwdriver to remove the four (4) screws exposed by removed rubber pads.
    • Use a small Phillips head screwdriver to remove the four (4) screws exposed by removed rubber pads.
  3. Use a spudger to pry the front cover off of the phone, gradually working your way around the front face.
    • Use a spudger to pry the front cover off of the phone, gradually working your way around the front face.
  4. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Use a spudger to lift away and remove the metallic frame (in blue).
    • Use a spudger to lift away and remove the metallic frame (in blue).
    • Use the spudger to lift away the two electrical contacts (in red).
    • Use the spudger to lift away the speaker (in yellow).
  6. This is what the rear of the LCD screen should look like before proceeding.  Note all necessary connections are undone.
    • This is what the rear of the LCD screen should look like before proceeding. Note all necessary connections are undone.
  7. Use a spudger to lift away the LCD screen.
    • Use a spudger to lift away the LCD screen.
  8. LCD screen successfully removed!
    • LCD screen successfully removed!
Заключение
Еще один человек закончил это руководство.
Kevin Jafarey
Участник с: 04.10.2010
11 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 3-24, Regan Fall 2010 Участник Cal Poly, Team 3-24, Regan Fall 2010
CPSU-REGAN-F10S3G24
4 членов
Автор 12 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 2,782
