Введение
If the AUX port isn't working, install a new one! This guide shows you how to change out an old AUX port that may not be working correctly.
Note: This guide involves soldering and should not be done by children. If you do not know how to solder, check out How To Solder and Desolder Connections to learn how before beginning this guide.
Выберете то, что вам нужно
Turn the device upside down.
Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
Using a Phillips #1 screwdriver, remove the screw found in the middle of the board.
To remove the faulty AUX port wires, de-solder the two wires on the white rectangular region of the board.
Carefully insert the new AUX port wires into their designated holes and solder them into place.
