Введение
The purpose of this guide is to show you how to open up your Audiovox. Once inside, you will be able to check out all of the different internal components, and begin repair if necessary!
Выберете то, что вам нужно
Turn the device upside down.
Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
Using a Phillips #1 screwdriver, remove the screw found in the middle of the board.
