Введение
This guide will teach you how to replace the speaker that are located within the device. The speaker can malfunction causing you to not hear the proper sounds from the lock.
Выберете то, что вам нужно
Flip the device so the back cover is facing you.
Undo the latches on both sides to remove the metal cover.
Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
Use the metal spudger to pry the plug off of the motherboard.
The plug can be dislodged when prying it from the side.
Warm up the iOpener.
Place the iOpener heating pad over the speaker and let sit for a few moments.
Using the metal spudger, pry some of the glue off the hinges holding the speaker in place.
Once the speaker looks mobile, flip the cover over and push below the speaker to pop it out.
Еще один человек закончил это руководство.
