Axess SPBT1031 Speaker (Horns) Replacement
Выберете то, что вам нужно
  1. Axess SPBT1031 Speaker (Horns) Replacement, Black Faceplate: шаг 1, изображение 1 из 1
    • Look at the side of the speaker that has the red interface plate. Using a Phillips head PH1 screwdriver head, remove screws on the top and bottom of the black face plate. There will be one screw on top and one on the bottom.
    • Both screws are 0.55 cm in depth
  2. Axess SPBT1031 Speaker (Horns) Replacement: шаг 2, изображение 1 из 1
    • Separate the black face plate from the tube by pulling them apart.
    • Be careful when pulling the wires apart or it will potentially damage the wires due to over stretching.
  3. Axess SPBT1031 Speaker (Horns) Replacement, Speaker (Horns): шаг 3, изображение 1 из 1
    • By this point you should have determined which speaker needs to be replaced, to figure this out please refer back to the troubleshooting guide.
    • For the top horn replacement, you will be working with the blue and white wire pair.
    • For the bottom horn replacement you with the yellow and white wire pair.
  4. Axess SPBT1031 Speaker (Horns) Replacement: шаг 4, изображение 1 из 2 Axess SPBT1031 Speaker (Horns) Replacement: шаг 4, изображение 2 из 2
    • To remove the plastic coating around the desired horn, look on the back of the black face plate you removed and use the philips head ph1 screwdriver fitting to remove the two 0.3 cm Philips Head screw and washer combos on the left and right of the horn.
    • Screw depth of 0.7 cm
  5. Axess SPBT1031 Speaker (Horns) Replacement: шаг 5, изображение 1 из 1
    • Lift the horn from its fitting by pulling it. Position it in a manner that is easy to work with.
  6. Axess SPBT1031 Speaker (Horns) Replacement: шаг 6, изображение 1 из 2 Axess SPBT1031 Speaker (Horns) Replacement: шаг 6, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Desoldering Pump
    $3.99
    Купить
    • Use a soldering iron to heat the two contact points.
    • Then use a desoldering pump to remove the liquid solder.
  7. Axess SPBT1031 Speaker (Horns) Replacement: шаг 7, изображение 1 из 1
    • Remove the wires--blue or yellow wire depending on the horn you are replacing--from the old speaker and remove the speaker from the fitting location.
    • For the bottom horn replacement, you will be working with the yellow and white wire pair.
Заключение
3 участников успешно повторили данное руководство.
Elvira Lou Evangelista
Участник с: 03/09/16
957 Репутация
Автор 6 руководств
Команда
UMass Dartmouth, Team 8-6, Botvin Spring 2016 Участник UMass Dartmouth, Team 8-6, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G6
3 членов
Автор 8 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 8
За всё время: 1,810
