Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
Use this guide to replace the side buttons on the Axess TA2513-10WT.
Запчасти
Детали не указаны.
  1. Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
  2. Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons. Slide the plastic opening tool gently along the sides. If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
  3. Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
  4. Manta Driver Kit
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta Driver Kit
  5. Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
  6. Orient the tablet's back cover so that the inside faces up and the buttons are positioned at the top left corner. Orient the tablet's back cover so that the inside faces up and the buttons are positioned at the top left corner.
    • Orient the tablet's back cover so that the inside faces up and the buttons are positioned at the top left corner.
  7. Unlatch the clear rubber holder from the posts with the tweezers. Unlatch the clear rubber holder from the posts with the tweezers.
    • Unlatch the clear rubber holder from the posts with the tweezers.
  8. With tweezers, pull the rubber holder from the back cover completely. With tweezers, pull the rubber holder from the back cover completely.
    • With tweezers, pull the rubber holder from the back cover completely.
  9. Remove the individual buttons with tweezers. Remove the individual buttons with tweezers. Remove the individual buttons with tweezers.
    • Remove the individual buttons with tweezers.
Заключение
Lori Scott
Участник с: 24.03.2015
101 Репутация
1 руководство автора
Команда
Baylor, Team 6-3, Shaver Spring 2015 Участник Baylor, Team 6-3, Shaver Spring 2015
BU-SHAVER-S15S6G3
3 членов
Автор 10 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 135
