Введение
Is your tablet no longer taking pictures? Fear not! This easy to follow guide will show you the proper technique for replacing the cameras.
Выберете то, что вам нужно
Begin by unscrewing the two 1.4 mm diameter Phillips #00 head screws at the top of the device.
Next, gently pry the cover off with a plastic opening tool or a similar instrument by loosening all of the anchoring points. Two of the anchoring points are circled in the image. Avoid excessive bending or pivoting, since doing so may break the anchoring points.
After prying open all of the anchoring points, the cover will lift off of the tablet.
Using a plastic opening tool, gently peel back the black electrical tape to reveal the power strip and the front facing camera, which is marked by the red box in the image.
Gently pull the front facing camera out of its mounting point. Use a spudger if necessary.
Using the spudger, pry the rear facing camera its power strip off the circuit board. This may require some force, since a strong adhesive is used to mount the camera assembly to that point.
Lift and remove the power strip/camera assembly from the device with a pair of tweezers.
