Введение
The heating plate under the basket could get dents or be damaged with usage. This could cause the basket to not fit as well and make it pop out. When that happens, the user should replace the heating plate with a new one. Thus this guide shows how to replace the plate.
Выберете то, что вам нужно
Turn the device off and make sure it is cooled down. Then place the device in front of you and take the drawer out by placing a hand on the handle and pull towards you. Make sure the plug is out of the way before starting any of the following steps.
Slide the clear lock away from the button and press down on the release button to release the basket from the drawer.
Turn the device onto its side and have the bottom surface face you.
Remove the 1.5 mm Phillips #1 screws from the bottom of the device. Rotate the screws counterclockwise with a Phillip's #1 screwdriver.
Place the unscrewed bottom cover next to the device without damaging the cords by extending them.
Unscrew all the 1.2mm Phillip's #1 screw around the silver plate by rotating them counterclockwise with Phillip's #1 screwdriver to take the plate off.
Locate 8 silver holds that holds the silver plate and black cover together.
Use a 0.1mm Flathead screwdriver to bend the 8 silver folds toward the center of the circle to release the silver plate.
Еще один человек закончил это руководство.
