  1. Use the plastic opening tool or your fingernail to pry off the back cover.
    • Use the plastic opening tool or your fingernail to pry off the back cover.
  2. Use the plastic opening tool or your fingernail to pry off the battery from the top right corner.
    • Use the plastic opening tool or your fingernail to pry off the battery from the top right corner.
  3. Use a screwdriver to remove each of the four screws. Use a screwdriver to remove each of the four screws.
    • Use a screwdriver to remove each of the four screws.
  4. Android Fix Kits
    A new screen or battery is one kit away.
    Купить сейчас
    Android Fix Kits
    Купить сейчас
  5. Take the plastic opening tool and insert it in the crease between the front screen and the inner back cover. Slide the plastic opening tool along the edge of the phone to pry the two covers apart.
    • Take the plastic opening tool and insert it in the crease between the front screen and the inner back cover.
    • Slide the plastic opening tool along the edge of the phone to pry the two covers apart.
  6. Insert the plastic opening tool between the black pad and the circuit board. Then gently pry off the black pad. This will make the connections of the charging port more accessible.
    • Insert the plastic opening tool between the black pad and the circuit board. Then gently pry off the black pad.
    • This will make the connections of the charging port more accessible.
  7. Using a soldering iron and a pair of pliers, melt the soldering connections around the headphone jack. Quickly pull off the current headphone jack while the soldering connections are still soft.
    • Using a soldering iron and a pair of pliers, melt the soldering connections around the headphone jack.
    • Quickly pull off the current headphone jack while the soldering connections are still soft.
  8. Mount the new headphone jack such that the prongs of the headphone jack line up with the soldering connections.
    • Mount the new headphone jack such that the prongs of the headphone jack line up with the soldering connections.
    • Using a soldering iron, solder the connections in place.
Итог
Lioma Terrero Soto
Участник с: 16.10.2014
489 Reputation
Автор 5 руководств
UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014 Member of UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G8
4 членов
Автор 5 руководств
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 371
