  1. Use the plastic opening tool or your fingernail to pry off the back cover.
    • Use the plastic opening tool or your fingernail to pry off the back cover.
  2. Use the plastic opening tool or your fingernail to pry off the battery from the top right corner.
    • Use the plastic opening tool or your fingernail to pry off the battery from the top right corner.
  3. Use a screwdriver to remove each of the four screws. Use a screwdriver to remove each of the four screws.
    • Use a screwdriver to remove each of the four screws.
  4. Android Fix Kits
    A new screen or battery is one kit away.
    Купить сейчас
    Android Fix Kits
    Купить сейчас
  5. Take the plastic opening tool and insert it in the crease between the front screen and the inner back cover. Slide the plastic opening tool along the edge of the phone such that the two covers are pulled apart.
    • Take the plastic opening tool and insert it in the crease between the front screen and the inner back cover.
    • Slide the plastic opening tool along the edge of the phone such that the two covers are pulled apart.
  6. Insert the plastic opening tool between black pad and the circuit board. Then gently pry off the black pad.
    • Insert the plastic opening tool between black pad and the circuit board. Then gently pry off the black pad.
    • This will make the connections of the charging port more accessible.
  7. Using a soldering iron and a pair of pliers, melt the four soldering connections around the charging port. Quickly pull off the current charging port while the soldering connections are still soft. Quickly pull off the current charging port while the soldering connections are still soft.
    • Using a soldering iron and a pair of pliers, melt the four soldering connections around the charging port.
    • Quickly pull off the current charging port while the soldering connections are still soft.
  8. Mount the new charging port so that the four prongs of the charging port line up with the four soldering connections.
    • Mount the new charging port so that the four prongs of the charging port line up with the four soldering connections.
    • Using a soldering iron, solder the connections in place.
Итог
Lioma Terrero Soto
Участник с: 16.10.2014
489 Reputation
Автор 5 руководств
UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014 Member of UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G8
4 членов
Автор 5 руководств
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 761
