  1. Use the plastic opening tool or your fingernail to pry off the back cover.
    • Use the plastic opening tool or your fingernail to pry off the back cover.
  2. Use the plastic opening tool or your fingernail to pry off the battery from the top right corner.
    • Use the plastic opening tool or your fingernail to pry off the battery from the top right corner.
  3. Android Fix Kits
    A new screen or battery is one kit away.
    Купить сейчас
    Android Fix Kits
    Купить сейчас
  4. Use a screwdriver to remove each of the four screws. Use a screwdriver to remove each of the four screws.
    • Use a screwdriver to remove each of the four screws.
  5. Take the plastic opening tool and insert it in the crease between the front screen and the inner back cover. Slide the plastic opening tool along the edge of the phone to pry the covers apart.
    • Take the plastic opening tool and insert it in the crease between the front screen and the inner back cover.
    • Slide the plastic opening tool along the edge of the phone to pry the covers apart.
  6. Locate the speaker Wedge the plastic opening tool between the speaker and the circuit board. Gently pry the speaker off the circuit board. Use a soldering iron to remove the two wires that connect the speaker to the circuit board.
    • Locate the speaker
    • Wedge the plastic opening tool between the speaker and the circuit board. Gently pry the speaker off the circuit board.
    • Use a soldering iron to remove the two wires that connect the speaker to the circuit board.
  7. Use the soldering iron to connect the two wires, that are attached to the speaker, to the circuit board.
    • Use the soldering iron to connect the two wires, that are attached to the speaker, to the circuit board.
    • Place the new speaker onto the circuit board.
Заключение
Lioma Terrero Soto
Участник с: 16.10.2014
489 Репутация
Автор 5 руководств
Команда
UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014 Member of UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G8
4 членов
Автор 5 руководств
Добавить комментарий
Просмотр статистики:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
За всё время: 406
