Введение
You may have to replace the screen on your phone due to unforeseen circumstances. Replacing the screen can be difficult, but with these straightforward instructions you will be able to replace the screen of a BLU Energy X Plus very easily. This process only takes one step and it comes after the Battery, Camera, Motherboard and Speaker replacement guides.
Выберете то, что вам нужно
Flip your device to the left side facing up and take out the SD card tray using the SIM card eject tool. You will insert the tool in at an angle and lift the tray up.
Flip your device to the right side facing up and use the SIM card eject tool to remove the SIM card by pushing the tool in the hole. You will feel a button click and the tray should slide out 2mm. You will then use your fingers to pull the tray out.
Take the blue plastic opening tool and insert it in-between the back of the phone and the chrome trim. Go all the way around the device slowly to take the back cover off.
Remove the six silver screws from the cover plate, and one black screw from the top.
Use the screwdriver head J000 to remove all the screws.
Six silver screws, all 1.5mm in length.
One black screw, 1mm in length.
After all the screws are out, lift the protective metal cover off of the phone. Lift from the bottom of the cover.
Use the small blue plastic opening tool to lift the contact attached to the battery from the motherboard of the phone.
Use the small blue plastic opening tool to lift the battery from the bottom with little force because the battery will be glued in.
Then, use your hand to remove the battery completely.
After loosening the glue from the bottom of the camera, lift the camera out of the phone.
Remove the black screw using a screwdriver head J000.
Lift the black tab on the zero insert force connector on the lower left side of the motherboard using a small blue plastic opening tool.
Lift the black tab on the zero insert force connector on the lower right side of the motherboard using a small blue plastic opening tool.
Lift the black tab on the zero insert force connector on the top left side of the motherboard using a small blue plastic opening tool.
Use a fine nose pair of tweezers to pull the ribbon cable from the zero insert force connector with little force to remove the contact connecter from the motherboard.
Lift the small processor using a pair of tweezers.
Then, lift up the motherboard using your hand, lifting from the top of the motherboard.
Remove the zero insert force connector that's on the back side of the motherboard using a small blue plastic opening tool to lift up the black tab. Then pull the motherboard out of the phone.
Remove the connector wire from the motherboard using your finger nails. You will need to pull from the gold colored connecter, which is attached to the motherboard.
And, there's your motherboard.
Remove the four silver screws using a J000 screwdriver bit .
Four silver screws, all 1.5mm in length.
There will be a fifth silver screw that is covered by a white sticker. Remove this screw using the J000 screw driver head.
One silver screw, 1.5mm in length.
After removing all the components you will be left with the screen, as provided by BLU.
7 участников успешно повторили данное руководство.
4 Комментариев
This guide is incomplete and will not show you how to remove your screen. It will show you how to disassemble your phone and feel like a fool.
where do i get the replacement screen from
You missing main part how to get to the screen
