Введение
In order to replace the vibration motor the user will need to have knowledge on soldering station usage. The battery does not have to be removed if the user is able to access the solder connections without damaging the battery. A larger tip on the soldering iron is more ideal in order to more quickly heat the solder without damaging the board.
Выберете то, что вам нужно
Detach the battery from the mother board using a plastic opening tool.
Use a plastic spudger to remove battery.
2 участников успешно повторили данное руководство.
