Введение
The back camera may become damaged or scratched over time, causing poor quality pictures. This guide will explain how to access, remove, and replace your BLU Life X8 back camera.
Выберете то, что вам нужно
Flip the phone over so that the screen is facing down.
Slide the opening tool between the micro-USB port and the back cover.
Use the opening tool to create a gap.
Once the back panel is off, locate the indent at the bottom of the battery.
Use your thumb to slip the battery out of the case.
Use the Phillips #00 (1.5mm) bit to undo the (9) screws from the back of the device.
Wedge the opening tool into the seam of between the screen and the gray frame.
Run the opening tool along the seam to release the clips that hold the two pieces together.
Use the tweezers to unlock the ribbon cable from the motherboard
The ribbon cable should be free. Pull back on the ribbons to release it from the connector
Еще один человек закончил это руководство.
