Введение
Over time, batteries lose their ability to hold a charge. If your BLU Studio G is losing charge quickly or won’t hold a charge at all, use this guide to replace its old battery with a fresh one.
Выберете то, что вам нужно
To remove the back cover, locate the safety indented notch on the bottom left corner as the screen is facing down.
Using your finger (or spudger), prop upwards to detach the back cover properly from the rest of the device.
Set back cover aside.
Locate the notch at the bottom of the battery for safe removal.
Carefully lift battery from the notch making sure not to puncture the battery rubber casting.
Set battery aside and insert new one .
