Введение
This guide will show the steps needed to remove the power supply from the BOSE SoundTouch 30.
Выберете то, что вам нужно
Remove the four 15.5 mm PH2 screws securing the base plate to the device.
Remove the six 15.5mm PH2 screws securing the grille and rear panel to the device.
Remove the grille and rear panel by grabbing the corners and pulling upwards and outwards.
Disconnect the three cables from the power supply by squeezing the white tabs if present and gently pulling.
Pick up the power supply and remove the fourth cable from the underside of the power supply.
Remove the power supply.
9 участников успешно повторили данное руководство.
29 Комментариев
where can we buy the [power supply unit, as i have messed mine by using 220v instead of 110v
Hello. Do you want to exchange power supplies?
Contact me please!
Hi. My name Josley from Brazil.
I need you Power supply module for bose soundtouch 30.
You can help me?
Hola donde puedo comprar el modulo SoundTouch 30 Power Supply.
Muchas gracias.
Isidro -
I have the opposite problem. Bought the 110v instead of the 220v and now I have to use a step down transformer. Wanna exchange power supplies?
tomas@familiarosales.cl
