Введение
Using a hex 2.0 driver, you will remove the top cover. using a pair of tweezers, you will then be able to remove and replace the Brck Motherboard.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Tweezers$4.99
Use the tweezers to grip the neck of the antenna(the part closest to the device).
Use opposite hand to twist off the body of the antenna.
Remove the four screws(4mm hex head) on the corners of the device with a Hex 2.0 Screwdriver.
Slightly lift the modem to reveal the brown ribbon connector and metal connection plate, located on the bottom of the modem.
Using your tweezers, gently push on the metal plate and slide it down toward the base of the modem to release the locking mechanism.
Lower the plate and gently pull the ribbon out of the face plate.
Remove the nut and washer from the RF connector, located where the antenna was connected.
Carefully insert tweezers under the black tab, and lift to release the clip.
Slide the ribbon out from under the clip to free the motherboard.
Slowly lift the motherboard out from the device by lifting it from the end next to the ribbon connection.
Lift and pull out of place.
